measuring groove diameters
Results 1 to 19 of 19
    turkey
    Default measuring groove diameters
    hi,
    I have a part that has two ring grooves,and I have to measure them on the machine before cut off the part.
    depth of the grooves about 80 mm and measurement range should be in 10 to 30.
    my all tolerance is 0.05 mm.(plus and minus 0.0025 mm)
    is there any equipment to use here, any advise?
    thanx.
    May 2010
    Denmark
    16,929
    3457
    7768
    Quote Originally Posted by bilalyaka View Post
    hi,
    thanx.
    Could you rewrite that again please?
    Depth 80mm but what is "range 10 to 30"?
    What are the widths of the grooves?
    I don't get "tolerance 0.05mm +/- 0.0025". Do you mean +/- 0.025mm?
    I'm certain I have something that can measure what you want but need more information.
    Jun 2006
    Thunder Bay Canada
    1,719
    468
    263
    Blade micrometer?
    Feb 2008
    Washington
    2,835
    Jan 2004
    Claremont, NH
    1,639
    9
    49
    Blade mic for flat bottom grooves, and in a pinch for round bottom grooves, measure over pins and subtract the diameter of both pins for the difference between your groove and measurement.
    May 2010
    Denmark
    16,929
    3457
    7768
    To those offering advice
    Do you know what the OP is looking for and it's just me that doesn't know?
    Try reading my post #2 and clue me in
    I'm pretty sure he knows there are blade micrometers and other instruments for measuring grooves and recesses so it must be a special problem.
    How does anyone get to be a machinist and not know how to measure a groove? I'm sure the problem isn't as simple as you think. Even the tolerance seems small for a groove diameter but of course I don't know the diameter to be measured.
    To give an answer I need to know more.
    Feb 2007
    Mid-Hudson Valley, New York state
    329
    25
    I'm going to say he wants to gauge groove diameters from 10-30mm in bores having depths around 80mm with +/- 0.025mm tolerance.
    Toronto,Canada
    78
    38
    26
    Quote Originally Posted by spope14 View Post
    I have to agree blade mic or pins are the way to go.
    Robert
    Jan 2004
    Claremont, NH
    1,639
    9
    49
    If this is an internal groove, then one can use an indical and a gauge block set-up to act as an ID type of calibration gauge. This is my tool of choice for ID grooves, round or flat bottom.
    Amazon.com: Indi-Cal Internal Groove Gage: Industrial & Scientific
    In fairness to gordon, the initial description is a bit sparse.
    May 2010
    Denmark
    16,929
    3457
    7768
    Looks like the OP has gone cold turkey
  11. #11
    Jun 2011
    Georgetown, TX
    356
    56
    40
    Ohhh, don't use that. I have one for emergencies and such, but damn it's a pain in the ass. It's very hard to make sure you've found the apex of the groove as well as have it square because it's so flimsy - the indicator bounces around at the slightest breath.
  12. #12
    Jan 2004
    Claremont, NH
    1,639
    9
    49
    Yeah, they are a pain, the indicals, I also have the bore gauge listed in the "customers also viewed". This said, I got used to using indicals a few years back doing work for a local shop and found quite a niche. I also like the indicator choice for accuracy. My method of keeping them sound and from gettign bounced is to use a spray bomb cap with a notch in it (made special with a precision X-acto knife) as the rest on the bench. They DO take a lot of p[ractice and patience. For an in experienced person, the dial gauge works quite well.
  13. #13
    May 2010
    Denmark
    16,929
    3457
    7768
    There's a smidgeon of sarcasm in my post when I write:
    I'm amazed at how much friendly advice is being given without even knowing what the OP is wanting to be measured and why it's even a problem to him.
    It was the OP's first post and perhaps his last yet look at the number of responses generated. Some even contradicting each other
  14. #14
    turkey
    yes it is true that it was my first post here but I think that it does not require answers as Clarke's.
    Of course I know about mics. but I have a internal groove to measure before cutting off the part to manage offsets.
    the width of grooves about 4mm, depth of measurement tip is about 3.7mm, I think there is a suitable one at;
    Mueller Gages Company - 1900 Series
    the diameter of bore is about 12.5 mm , tolerance of the groove diameter is +/- 0.025mm so the equipment accuracy should suitable this tolerance.
  15. #15
    Feb 2008
    Washington
    2,835
    See?
    I have one, and it has both .0005 resolution and a .0001 resolution indicator. I rarely use it, but when I need it I have it.
    Ebay will have one periodically.
  16. #16
    May 2010
    Denmark
    16,929
    3457
    7768
    Now if you'd written that from the start that would have been great Have you noticed how many suggested how to measure external grooves?
    As I started off by writing I have something that can do as you need but so do many others.
    The instruments you have a link to can do what you want but it can be done for much less. As with all internal measuring instruments you'll need something with a known diameter as reference.
    As you seem a bit touchy then just for the record I didn't write answers. I wrote asking for more information with questions. That you don't seem to ride the same day as you saddle up is something else again
  17. #17
    Mar 2006
    USA
    60
    IF...you know your machine and technique is sound and accurate, one thing I have done in the past working for companies that either couldn't afford or just wouldnt buy nice I.D. measurement tools is cut something I had access to and could measure accurately to offset the tool. You can use this technique on diameters and lengths. You would have to have material in the area your cutting to try to duplicate your cutting conditions as much as possible. It is also a very effective way to dial in long taper moves that you may not want to make a full pass on to adjust. Condition of machinery is a factor when doing this so you would need to be confident in the machine capabilities.
  18. #18
    May 2008
    Great State Of Wisconsin
    444
    5
    Quote Originally Posted by Gordon B. Clarke View Post
    Thanks Gordon......good late night chuckle.....well said. I have not heard that expression in some time now
    bialalyaka....Gordon was just poking but more info at the start would have cut out all the speculation as he was pointing to.
    Sorry I had no value to add to the thread
    Stevo
  19. #19
    May 2010
    Denmark
    16,929
    3457
    7768
    Quote Originally Posted by stevo1 View Post
    Stevo
    Maybe no added value but you "made my day" LOL
