milling 1018 steel
Results 1 to 8 of 8
    Jun 2008
    Covina, CA USA
    56
    Default milling 1018 steel
    Hey guys:
    I've got a little problem. I'm trying to get the most life out of my 5/8" insert cutter (Mil-Tec). I'm using the largest radius they offer. I'm pocketing 1018 steel. (.194" deep). I've tried running dry, coolant, but it's not directly on the inserts. I was cutting .0625" depths at 8500 rpm & 105 ipm.
    I'm down to 7500 rpm .045" depths and 90 ipm.
    I'm helical plunging at 12 ipm. If I run it dry after maybe 6 or 7 parts, i'll get a spark show during the helical plunge. I can't run more than maybe 19 parts total. This is a piece of steel that is 6" long x 2.75" wide.
    Do I take .025" depths of cut? They won't let me order inserts. I got this tool for free. I have to wait until monday for the rep. I'll hook him up on some items here for some tooling. I'm using the recommended grade insert for the material.
    Any and all info is greatly appreciated.
    Ron - Ontario, CA
    Mar 2006
    Tennessee
    2,003
    249
    363
    You didnt say how many inserts in the tool so i cant figure the chip load. your best bet is to machine the part going full depth since this minimizes how many times your corners see action basicly more passes equal more linear feet your cutter has to travel. Have you considered a variable helix carbide mill? Im seing around 1000 liniear feet before my 1/2" varimills give out at 4200 rpm 39" per min.
    Jun 2008
    Covina, CA USA
    56
    I'm sorry...it's a 2 flute insert cutter.
    Ron
    Oct 2006
    Klamath Falls, Oregon
    3,467
    355
    864
    You didn't mention the size of the pocket or the radius of the plunge. With non-centercutting tools, the arc of the helical plunge has to be at least twice the diameter of the tool, so the center of the tool is never plunging. If your arc is smaller than 2x the diameter, you'll be mashing the metal out of the way instead of cutting it. Your other option is to pre-drill a clearance hole and plunge the cutter over the center of that and go to town.
    Mar 2002
    Brisbane, CA, USA
    1,671
    73
    191
    Ron-
    In mild steel with carbide, my rule of thumb for RPM would be:
    RPM = 4 x SFM / DIAMETER = 4 x 400 / .625 = 2560 RPM
    Some inserts will do better than 400 SFM in mild steel, but even if you figure 800 SFM your RPM seems way too high.
    I'd find out what SFM is recommended by the manufacturer for these inserts in steel, but if you can't find that info try knocking your RPM down to around 3000 and see how it cuts.
    To figure a ball park feed rate and chip load, I use the rule of thumb:
    Chip Load = DIAMETER/200 = .625/200 = .003125
    Feed Rate = RPM x Chip Load x Num Flutes = 3000 x .003125 x 2 = 18.75 ipm
    That's a starting point RPM and feed rate, if the machine can handle it bump up both and see how it reacts, but I don't think you'll be able to get back up to 8000 RPM and have the inserts live very long.
    Paul T.
    Jun 2008
    Covina, CA USA
    56
    Sorry about the lack of info.
    The pocket is 5.4" x 1.8"
    I'm going to run it at .150" depth @ 25 ipm & 4500 rpm and see what happens
    With the other side of the inserts. With coolant
    Ron
    Feb 2005
    8,183
    11043
    9071
    I would knock the SFM down a bit, 1300sfm is pushing it, you could get away with that with a narrow engagement, but not with full slotting. I would knock it down to under 800sfm, and probably start out at about 5-600. Feed maybe .003 per tooth full depth.
    Also I much prefer a straight ramp than a tight helix into the material. You end up plunging at a steeper angle than you intended on the inside of the helix, seems a little tougher on the tools. If you ramp the 5" across, you'll be at the bottom in a single pass, no need to feed to slower on the ramp than you are going to cut the pocket.
    Also dry, at those speeds your inserts will be nicely shattered pretty quick.
    Jun 2008
    Covina, CA USA
    56
    I put my rpm back to 6,000 and i'm cutting .055" depths. @ 72 ipm
    I called Mil-Tec directly. I told him I would do a full depth cut..but I don't have any change if something really bad happens. I know it's not major machining or anything...but I just don't have the resources to get new tooling as much as other places.
    Thanks for your help guys.
    The cutter is holding up pretty well so far.
    I made my arc as big as I could for the pocket..I think that helped the most.
    Ron
