The OP is kind of talking about 2 different things. Now from what I know G16 will be in lines with polar rotation which will tie in with a rotary axis. This may or may not be similar to G12.1 for polar interpolation (Bill aka angelw) is going to know this cold.
However Fred is correct that G68 appears to be what the OP is looking for as stated in post #5. G68 will be an option that needs be active in the control so you may get an "improper G-code" alarm when trying to use it. If this happens send me a PM.
Now if this is the case then a macro or a looping sub program will be the best approach to program the typical shape around the part.
Stevo
Hi Stevo,
Yes, I interpret the OP's thread as you do. If he wants to use the same NC data for a complex feature, indexed and repeated around an axis, then G68 is what he would use.
G16 is similar to G12.1 in that they both relate to angles, but in an opposite way. The difference between the two, is that G12.1 (Polar Coordinate Interpolation) is applied when a rotary axis is involved and the tool path is programmed with no consideration whatsoever to an angular command that would normally be applied to the rotary axis. Its a function that exercises contour control in converting a command programmed in a Cartesian Coordinate System to the movement of a linear axis and the movement of a rotary axis . Conversely, G16 allows slide positioning to be made via Polar Coordinate System, that is, coordinates defined by an angle and a distance. And as you know Stevo, you have to set linear and rotation axes for Polar Coordinate Interpolation in parameters beforehand, whereas with G16 you do not; there is no virtual axes swapping involved when using G16.
Following is an example of G16 being used in conjunction with a drilling cycle and Absolute mode.
N1 G17 G90 G16
G81 X100.0 Y30.0 Z–20.0 R–5.0 F200.0
Y150.0
Y270.0
G15 G80
In the above example, holes will be drilled at the Absolute angles of 30.0°,150.0°, and 270.0°, with a radius of 100.0mm from the Polar origin
The following example uses Incremental mode to specify the angle. Note that the first hole position is specified in Absolute mode to set the radius of the hole from the Polar origin and the Start angle . Subsequent angular moves are then made incrementally.
N1 G17 G90 G16;
G91 Y120.0
Y120.0
G15 G80
In the above example, holes will be drilled also at the Absolute angles of 30.0°,150.0°, and 270.0°, with a radius of 100.0mm from the Polar origin.
Regards,
Bill
