Milling with G68 Rotation (Haas Mini Mill)
Results 1 to 12 of 12
    Aug 2006
    Rheinstetten (Germany)
    Post
    I am trying to mill with this program below,but it`s not working. I allways get alarm mesgs (Alarm Nr310 Invalid G Codes: G code not defined and is not a macro call) can anyone help?
    Thanks Salsa
    Programing (Example)
    G54
    G00 G90 X50 Y-50 (Center )
    Z-2
    M97 P200 L8
    G00 Z30 M30
    N100
    G00 X28
    G01 Y0 F100.
    X52
    Y-50
    G00X50 Y-50
    M99
    N200
    G68 X50 Y-50 R45
    G90 M97 P100
    G69
    M99
    Aug 2005
    CT
    7,486
    241
    1524
    Post
    Coordinate rotation and scaling is an option on HAAS, and must be enabled in the parameters page.
    See if it is enabled. If not, try DEMO to get 200 hours worth of it.
    Jan 2006
    los angeles
    408
    Post
    no decimal points?
    Aug 2005
    CT
    7,486
    241
    1524
    Post
    Decimals are not necessary, and teir value depends on the settings page.
    50 may mean 50. or .005
    Jan 2006
    los angeles
    408
    Post
    oh really, cool. did not know that one.
    Jul 2006
    Tucson, Az
    503
    57
    118
    Post
    Never used a machine that didnt use decimal points. It seems to me that it is just one more way you can screw yourself up. Do you guys like it, or just deal with it?
    Aug 2005
    CT
    7,486
    241
    1524
    Post
    Chobin
    If you read some of the Okuma posts from Wade, you'll see that his control won't even accept decimals anywhere. I think some older controls were that way, and for compatibility reasons new ones have the ability to use old programs with no decimals.
    Personally, prefer decimals hands down.
    Mar 2006
    Southeast Kansas
    702
    Post
    Fanuc 7M controls don't use decimals either. You have to be very careful when inputting numbers. One missed digit will likely cause a crash. I was so glad when ours finally died.
    Jun 2006
    Rocklin, CA,USA
    464
    6
    Post
    Salsa, also had problem w/g68 in side of sub program...had to put a separate g68 for each sub call. also using Haas.
    Aug 2006
    Post
    Thanks Guys, the option G68 Rotation is not enabled. someone told me that I need a code to do that. Does anybody know how it works?
  11. #11
    Aug 2005
    CT
    7,486
    241
    1524
    Post
    Salsa
    That is an option you can buy. Unlike Fanuc though, you pay them and they give you the code over the phone so no service call is necessary.
    However, it is possible to put it in DEMO mode for 200 hours.
    Parameter 57 - ENA ROT & SC. I think the code is demo.
    First change Bit7 in settings to OFF < PARAMETER LOCK>
  12. #12
    Aug 2011
    south carolina u.sa
    Default Haas
    Man, i working with a Haas TM1, and al is about the settings... 51 door open, 15 t and h.....
