I am currently building a CNC machine to make aluminum molds for my composite parts business and I wanted to ask you guys for opinions on which type of spindle is best for this purpose.
I am building the machine on a fairly tight budget but I have a choice of going with either one of the high speed Chinese CNC spindles off eBay (a 1.5kw or 2.2kw) or buying one of the 1/2hp low speed milling heads from Little Machine Shop. The decision is confusing me...
There are a lot of conflicting opinions on what set-up is optimal for machining aluminum. Some say I should buy the most powerful CNC router spindle I can afford and cut at higher speeds. Other say you get a better / more precise finish from a low speed milling head.
I have also read that you can't directly compare the specs of router spindles and milling heads because 1/2hp at 2500 rpm is worth more than 1/2hp on an 18,000 rpm spindle.
Both options cost around $350 all in. My main concern is the finish quality. Speed is not important to me at all.
Even though I'm building on a budget, it will still be a fairly rigid machine. The frame is all steel and aluminum. The rails are all THK and the gantry is carbon fiber and aluminum and quality ball screws are used for motion. I mention this because the machine will be rigid enough for the choice of spindle to matter.
What type of spindle would you guys choose for making aluminum molds from the options my budget allows?
