Eric U
Hot Rolled
- Feb 26, 2003
- Eastern AL
Guess this will be my question of the day...
Live tooling on my Doosan Lynx. Trying to mill a profile on the end of an aluminum bar with mixed results. Yes, I'm getting it to cut, but it is squealing like a pig. Doesn't seem to matter what speeds or feeds I try, the finish is pretty bad. Everything from 6000rpm 50ipm to 4000rpm 25ipm...all different variations. Tried to just skim off .001" up to 25% tool radius. From full depth (.425") profiling, to steps of .15" deep. I used 3/8" aluminum specific endmills from Maritool, with .030" corner radius and ZrN coating (destroyed one of them). I've got only the flutes sticking out of the collet. Tried both my Heimatec and Eppinger live tools. Are the ER20 and ER25 collets just not rigid enough? When I run 3/8" on my mill I always put them in ER32's.
Am I just expecting too much with live tooling? I know rigidity isn't what a machining center would be, but this kinda sucks. Should I try different endmills? Bigger diameter? Endmill holder instead of collets? Variable flute? I need the .030" radius for a feature on my part. Not too many .030" corner radius variable flute endmills out there for aluminum.
As usual, I'm all ears.
Eric U
Eric U
