Servo . CPP(211) assertion failed. This is on a Bridgeport knee mill CNC with Version 1.3.1
I didn't have any failures with version 1.2.1 then my hard drive went so I replaced the hard drive and up graded to the latest version my mill will run and now I'm getting a fault at start up. When I restart sometimes it will start normally. And home and seam to be ok until you start programming it. If you stop it with the stop soft key and change the program a little the servo motors lock. Then you get a CPP (673) assertion failure. Any suggestions on how to fix this would be great??
