JMC
Cast Iron
- Aug 30, 2007
- Northern Utah
All,
I have been given a project where I must reach right about 10 1/4" deep with a 1" cutter. The part will be set up on a 50 taper horizontal. I thought I found a source for the tools that I need to reach this length....using modular screw on heads, as the attached pic shows. Korloy has a carbide shank in their catalog that would allow me to reach this depth and have plenty left to put up in a holder. unfortunatly no stock in the US or Korea. Anyone got a source for some LONG extensions that will allow me to reach this depth AND give me a couple of inches to hold on to? I have looked and I can get there by stacking up extensions, however I would rather have a 1 piece setup. No particular brand loyality, as long as the thing works.
I did notice that Dapra has an 11" long extension that would work but is made of heavy metal (tungsten) rather than carbide. Seems to me that on this much of an overhang, I want as much rigidity as possible, so not sure if heavy metal would work. Screw-On Tool Heads & Modular Extensions | DAPRA
Thoughts/advise?
Thanks!
Thoughts/advise?
Thanks!
