dstryr
- Jan 22, 2010
- Nampa Idaho
I think he wants to know what feature youre indicating on the pallet
.I'm getting it off by .003. I figured it should be way closer than that. View attachment 148050
it is called grid shift. i check machine usually weekly. on horizontal you put test bar in spindle. use magnetic base and indicator on pallet zero to test shaft in spindle, move in Z til indicator clear of test shaft, rotate pallet, move back in Z to read indicator see what other side of test bar reads. grid shift adjusts so when zero return or homing done you are centered on table rotation.
usually there is a procedure on how to do grid shift. it often requires turning parameter write enable on and then editing parameters and turning parameter write enable off, powering down and restart, zero return, retest of course (easy to go opposite way)
many machines will go out of calibration .0005" just by being cold and not at running temperature. grid shift should be done after running a warm up program
.You are confusing center of the pallet with center of rotation?
The bore in the center of the pallet is .0035 off from center of b axis rotation.
Why whats going on with Mori?
.Nothing is wrong. Was just planning on building a bunch of fixtures that use that bore to locate me on center but then I found it wasn't right.
I guess I'll just stick to using a rubber mallet and an hour of indicating it in.
Slap on some edge stops and build fixtures to suit. Then you don't have to worry about stabbing a close fit pin and bore while dangling a heavy ass fixture from the forks of a lift truck (or a crane if you're fancy like that).
How close does the pallet edge measure to 250mm from B center?
Notice
