Finegrain
- Sep 6, 2007
- Seattle, Washington
Hi Guys,
I just moved a 1980 Mori Seiki SL-2B with Yasnac 2000G control to my shop. All worked fine before the move. Now, all the mechanicals work fine and code can be loaded into the buffer, but Cycle Start just plain doesn't do anything.
Things I've tried:
Simple MDI command, T0101, loads OK, but Cycle Start doesn't execute it.
Simple G-code, uploaded with multiple DNC's, code is seen in the buffer on the control, I can step through it, but Cycle Start won't run it.
Jog, 1H and 10H pulse, Rapid, Zero Return, all these work fine.
Turret indexes fine, spindle turns fine both directions. Coolant and hydraulics motors work fine, 500 PSI hydraulics.
No NC alarms are shown at the control.
No obvious loose things in the cabinets.
Cycle Start switch seems mechanically fine according to my Fluke 87.
Any advise, BTDT's, words of wisdom? Mori tech is so far stumped.
I'm sad . This is my first step into CNC, and so far all I have is a 7000# manual lathe with 8" of X and Z .
Thanks, and regards.
Mike
Things I've tried:
Mike
