Bill in PA
Hot Rolled
- Jan 25, 2011
- Fairfield, PA
Hello,
Mori SL-1 (1981)
Yasnac 2000GII with CRT
Not sure the make of the BTR
Precision DNC Free Edition for transmitting.
Previous owner was able to send programs to the control (I think using Mastercam to transmit). However, I have not been able to get it to work. I have the serial cable that he used. 4 wire: receive, transmit, ground, and frame ground.
Settings:
Even parity
7 bits
1 stop bit
300 baud
software handshake (have tried all the different settings)
NUL for EOB (control parameter is set for ISO)
- tried LF also
Sample program:
N001 G0 G96
N002 M30
DNC displays success message when transmitting to BTR. However, tape in gives a 8-14 error. Control indicates "format error", and book lists it as "DNC framing error or overrun error." Same error if I "tape in" without first sending program to BTR.
I did try and send one of his programs and got the same error.
Is there a way to know if indeed the BTR has received the program?
Any other ideas?
Bill
Mori SL-1 (1981)
Settings:
Even parity
7 bits
1 stop bit
300 baud
- tried LF also
Sample program:
N001 G0 G96
N002 M30
Any other ideas?
Bill
