Matt@RFR
Titanium
- May 26, 2004
- Paradise, Ca
Hey guys. I'm in the market for another mill and my tooling salesman suggested looking in to MQL instead of a 1,000 psi thru coolant system. This seems to be a pretty new thing since I'm struggling finding much information on it. I understand the concept, but I'm looking for every day experience with this type of system. I am NOT talking about a $200 mister for band saws and manual mills here.
- Does this work for small through coolant twist drills? I just finished a job that had a total of 3700 ø.028" holes .705" deep and 1920 ø.093" holes the same depth in 6061 (and these were prototypes ). Used Mitsubishi MWS drills for this and they worked well with my 320psi through coolant, but it seemed like I could have really cranked the feed with more pressure (or flow). MQL makes sense in my mind for this application. The holes in the drills are something like .003-.004" diameter.
- Does this work well with larger drills? And coolant through face mills? And would it work with running through coolant with a standard ER collet (flushing out a pocket, etc.)?
- I have a Royal mist collector on my current mill and will get one for the next mill. Will they suffice for the fog that I assume these systems create?
- What about for general milling? I use HSM for damn near everything so lots of heat in the part isn't too much of a concern, but I'm curious if these systems actually remove chips from the part or if they tend to get stuck in the oil film on the part. I'm thinking finishing passes and 3D stuff here. I suppose I could have the standard coolant come on as needed to rinse the part?
Any other thoughts or input?
