I need help from some experienced cnc'rs...I am drilling 61 holes that are .020" OD into .05" thick brass. I put my spindle rpm to about 3000 and doing .4" Plunge rate into .05" thick brass. I am using my cnc mill but I notice my drill bits keep breaking.
I did notice that when I blew the brass chips off that it seemed to stop the breaking. Could brass swarf , even small as .020 drilling into .5" thick brass, at a .4" plunge rate, cause the drill bits to get stuck and break? Or is there a better Plunge rate and RPM that I should be using? Also, should I spot drill the 61 holes first?
I am new to this , so I am thinking maybe I should be having to blow air to clear the small brass swarf while drilling? Any help please as I need to make quantity pieces doing this 61 hole drill set up. Thank you for any information/help and your time doing so!
