To make a long story short I have a 1996 Kitamura Mycenter-1 machine with a Fanuc OM control that is having problems with the tool changer. I had the machine off power for about two months leading to the loss of the parameters. I had a backup copy that I inputed but now the machine's side mounted tool magazine is not working properly. When I call a tool the magazine turns to place the correct tool in position put the pin that unlocks the pot does not stay engaged. The pin just repeatedly goes in and out until I either E-Stop the machine or press the reset button. Does anyone have any idea what could be wrong? Is there a parameter that could be wrong? I have talked to Kitamura and the most helpful tip I got was that perhaps the pin is not entering the chamber smoothly and that some manual tweaking to the encoder could help. I have tried this but it only seems to misalign the pin and the chamber it goes in to unlock the pot.
The machine was working perfectly before this so my guess is that it could be something related to the parameters rather than something mechanical. I do have a nearly identical machine that I can look at. Any help would be appreciated. Thanks in advance.
