Mystery spindle
Results 1 to 14 of 14
Thread: Mystery spindle
    Jun 2010
    Vermont
    110
    Default Mystery spindle
    Hi folks,
    I have two items that I'm guessing are independent CNC axis spindles, but 'I don't know from' CNC components or terminology. Can any of you help identify what these are?
    Attached Thumbnails Attached Thumbnails 20171204_202211.jpg   20171204_202220.jpg
    Jul 2006
    Hillsboro, New Hampshire
    4,141
    864
    2760
    Doesn't seem to be anything CNC, just a high-speed spindle attachment, perhaps for internal grinding or small endmills. There's no servomechanism on the assembly, just a low power motor to drive the spindle. Does look well made though.
    Is the knob or stem on the right, just to the left of the mildly rusted area a spindle lock? Do make sure the spindle is free moving and lubricated before trying to run it.
  3. Likes Ox liked this post
    Jan 2014
    Vancouver, WA. USA
    2,699
    540
    1345
    Kind of reminds me of a pantograph spindle. It's been like 40 years since I saw that machine, but something is bringing that to mind.
    Mar 2001
    Switzerland
    2,419
    2008
    993
    That's from a transfer machine. Sort of like the pic.
    Jul 2006
    4,141
    864
    2760
    Quote Originally Posted by Screwmachine View Post
    Perhaps, but it's awfully light duty for that. I'd tend to go with Vanbiker's pantograph or engraver spindle, seems a lot more likely.
    Mar 2001
    Switzerland
    2,419
    2008
    993
    I've seen transfer spindles that weren't much more than an inch diameter.
    Jun 2010
    Vermont
    110
    Doesn't seem to be a spindle lock - more like a vacuum line. Here are some more pictures, the last one showing where the hole from the vacuum line could line up with the spindle assembly, shown in the other pictures. I can't move the spring loaded part, so there may be an interlock on that. Seems to be heavily spring loaded, with (large?) oil reservoir in the anodized cylindrical part visible in first picture at start of this thread.
    Attached Thumbnails Attached Thumbnails 20171205_231057.jpg   20171205_231113.jpg   20171205_231123.jpg   20171205_231311.jpg   20171205_231315.jpg
  9. #8
    Jun 2010
    Vermont
    110
    A few more pictures.
    Attached Thumbnails Attached Thumbnails 20171205_231356.jpg   20171205_231328.jpg
  10. #9
    Jul 2006
    4,141
    864
    2760
    What a curious design. Perhaps that lower fitting is an air purge to keep chips out of the nose bearing, but I can't see what the two posts and spring are for above the driven sprocket. I'd think they present a balance issue, but going by the drive and driven sprockets the max spindle speed can't be that great. Any sign of it being a release for a nose collet? Maybe a pneumatic chamber inside the spindle for for tool clamping??
    And that it's a timing belt is interesting too. So little torque available to the spindle I'd have thought a flat belt would be enough.
  11. #10
    Jun 2010
    Vermont
    110
    Yes, I'm having the same sort of thoughts/questions. Maybe the spindle is running on an air bearing in there (unlikely, but possible?). The two posts with the spring look to be driven by the large hydraulic looking gold anodized section. It's center post contacts the top of the pin that threads into the collet and there's a micrometer type wheel, presumably for depth adjustment. So it looks to me as if you fit the collet, insert tooling, tighten the collet and then leave the tooling in place (it does not appear that you can change tooling quickly or easily). Since I can't depress the two rods/spring, I'm guessing that the air coupler might be a release mechanism for the spindle and then the hydraulic actuator controls the tool depth (presumably something would be pushing on the upper steel rod extending from the end of gold anodized portion. Like you, I'm wondering about that toothed belt. More pictures in a little bit here ...
  12. #11
    Jun 2010
    Vermont
    110
    Ah ha, Dr. Holmes - a subtle but all-important clue! Brand name clear as day on the end of the anodized column
    Mystery solved - tooling from a transfer machine:
    Imoberdorf
    So the prize goes to Screwmachine; correct as always!
    Many thanks.
    Attached Thumbnails Attached Thumbnails 20171206_210621.jpg   20171206_210519.jpg   20171206_210504.jpg   20171206_210442.jpg
  13. #12
    Jul 2006
    4,141
    864
    2760
    Quote Originally Posted by StarkFan View Post
    Many thanks.
    I should have heeded that old saying: "Never argue with the Swiss when machinery is the topic!"
    Now I'd just like to understand what all the gubbins do...
  14. #13
    Mar 2001
    Switzerland
    2,419
    2008
    993
    Ha- not Swiss, just been here a couple of decades. South Carolina isn't really a watchmaking hot spot.
    I don't know a thing about transfer machines, just seen them around and had a few different spindles in my hands, always beatifully made.
  15. #14
    Jun 2010
    Vermont
    110
    I doubt that the mfg will have time for me, but I'll query re: how it is supposed to function, specified oil and post any further news. I'll eventually take one apart and append any further news from that as well, just for the record.
