When I first read your post referring to an Ethernet connection with an 11 series Fanuc, I had to refer to my notes before replying, as I was fairly sure Ethernet was not available on that control.
Some pundits use an RJ plug at one end of the cable to hook into switch boxes, but eventually, it has to connect to the PC’s com port.
To send to, and receive programs from the control, you use the Edit mode. The fact that it has a Tape mode is a bonus, because you use Tape mode when drip feeding programs that are too big for the memory of the machine.
My bet is that the alarm you are getting reads something like, “Data set ready signal of Rs232-C interface is turned off”; post the error number and I’ll be able to tell you what it means. If I’m correct, the plug pin out at the machine end is wrong, not plugged in fully, or the cable from the connector on the machine is not connected to its PCB board.
If this is the error that you’re getting, the first thing to check is the plug at the machine end, as it needs the following pins bridged to keep the machines Uart happy, they are 4 to 5 and 6 to 8 and 20. The complete pin out for the cable is as follows:
Machine End ---------------- PC End
DB25 Connector ------------- DB9 Connector
2 ------------------------------ 2
3 ------------------------------ 3
7 ------------------------------ 5
4 and 5 bridged
6, 8 and 20 bridged
DB25 Connector ------------- DB25 Connector
2 ------------------------------ 3
7 ------------------------------ 7
4 and 5 bridged
6, 8 and 20 bridged
The above cable will allow you to use XonXoff handshaking, look at parameter #5110; if the control has been set up for XonXoff, this parameter setting will be either 1 or 3.
Some communication software can check the comms settings by scanning a short data steam sent to it by the machine’s control. If this is not the case with your software, you will need to check parameters to determine the stop bits and baud rate set at the machine. Most machines of this vintage used “e,7,1” for the parity, data and stop bits; these are setting you need to set at the PC end, along with the baud rate setting of the machine.
Best regards,
Bill
