evidence_UA
- Nov 23, 2015
Hi,
need your help, guys. Have a medium rpoduction run for attached part but it goes really slow with my specialists so i want to ask advice overseas
Below is a image of part. The steel is c45 steel, the sizes in millimeters. With current strategy we waste around 1 hour for 1 part - the strategy is simple - mill with 2d raster from top, then machine every side. But i'm sure that that part can be done in half an hour or less with an appropriate tool and strategy.
Im not a CNC programmer but i want to try the different strategy, i have attached on the image below. I think, its clear - that we rough from these 2 sides, then place it like on the top image - cut the slot, make finish pass on plane, drill the holes and chamfer. The the other side with 52mm face mill. Done.
Can anyone advice me a good price/quality mill on that? I have an 12000rpm/18.5kW spindle and want to go at least with 150m/min (500sfm) and 1.5-2m/min of feedrate (80inches per minute) with Ae=5-10mm and Ap=20-45mm. Is there any way i can calculate if my spindle power is capable of such speeds and feeds?
But the main problem is - the price. I cannot afford 1mill per part. I need it to machine at least 20-30 parts or even more to make some profit. So the Sandvik with 800USD is not my choice, i think
The surface finish for that part is not a matter, because of further sanding and chem.oxy, but we need at least ra6.3 on base planes and slot
