Results 1 to 9 of 9
    PixMan's Avatar
    PixMan is offline Diamond
    Jan 2007
    Central MA USA
    4,136
    Default Need help finding CAT30 shell mill holder
    I;ve got a friend with a Robodrill and he wants to use a 2" carbide insert shell mill on finishing aluminum. Neither of us seem to be able to find a CAT30 holder with a 3/4" pilot diameter.
    Does anyone know of a company selling one? I checked Lyndex-Nikken, Teknics, and Parlec. No luck.
    Alloy Mcgraw is offline Stainless
    Aug 2010
    Eastern CT USA
    1,081
    Mari carries them in Bt30, but doesn't help in the toolchanger dept.
    dstryr is offline Stainless
    Jan 2010
    Gilroy CA
    1,111
    Quote Originally Posted by PixMan View Post
    If you cant find one you can get an AB tool one and cut the shank. it goes in a solid endmill holder Shear-Hogs (Shank Style) - AB Tools Inc
    PixMan's Avatar
    Jan 2007
    Central MA USA
    4,136
    Quote Originally Posted by dstryr View Post
    Nice idea, but those cutters are noisy and have expensive inserts. Moreover, the reason he needs the holder is because he's got a brand new expensive cutter & a near lifetime supply of inserts sitting there.
    I also had found them in BT30, but I'm pretty certain that a Robodrill T21 takes CAT30.
    Joe Grissom is offline Plastic
    Mar 2012
    Ohio, USA
    There is a used one listed on ebay now for $29.99 in Ohio.
    3t3d is offline Titanium
    Nov 2004
    WI
    3,560
    All the Robodrills that I own take BT30.
    Your search may be simpler than you thought.
    I am not aware of any Cat30 tool holders or spindles.
    I could be wrong, I have lead a sheltered life.
    LKeithR is offline Cast Iron
    Langley, B.C.
    386
    Quote Originally Posted by 3t3d View Post
    That's always been my understanding, too. The CAT designation only applies to 40 and 50 taper toolholders. The 30s are either BT 30 or NMTB 30. I think you'll find that any 30 taper holder will work...
    PixMan's Avatar
    Jan 2007
    Central MA USA
    4,136
    THAT makes sense! And it's probably why we can't find a holder.
    I will go to his shop and look. I know the difference between BT and CAT flanges just from looking at them from 20 feet away.
    An NMTB30 cannot be used in a Robodril, no way. It has no way to clamp the tool nor hold in the turret.
    Question Boy's Avatar
    Question Boy is offline Hot Rolled
    May 2005
    Napa, California
    940
    Quote Originally Posted by LKeithR View Post
    I have a CAT30 holder, had to modify it to fit a BT30 spindle by making the drive dog slots symmetrical. That said, I've never seen a CAT30 Robodrill.
    QB
