Hey guys - having a bit of trouble here with a Cincinnati Lancer VMC - Acramatic 2100 control. I don't do a ton of programming on these with the conversational that's on them, but this morning I had a request for an engraving program. This is about the 4th time I've had this struggle and I haven't yet figured it out. Code below...control catches error on N108. When I ran into this problem last time I thought for sure it had something to do with cutter comp - then tried reprogramming with control, computer, value in diameter, no value in diameter and couldn't figure anything out. This is just a straight no comp program, and I can't figure why it won't go. I believe we can increase the endpoint tolerance, but I'm hoping someone with more experience programming these machines can steer me in the right direction.
( MSG, TOOL - 1 | 1/32 FLAT ENDMILL | TOOL DIA. - .03125 )
:100 T1 M6 D0
N102 G0 G90 X4.4587 Y-.3214 D1 S4000 M13
N104 Z.1
N106 G1 Z-.015 F2.
N108 G2 X4.5824 Y-.25 I.1237 J-.0715 F8.
N110 G1 X4.5935
N112 G2 X4.7362 Y-.3864 I0. J-.1429
N114 X4.6993 Y-.476 I-.1427 J.0064
N116 X4.5709 Y-.5719 I-.7722 J.9005
N118 G3 X4.448 Y-.75 I.116 J-.2115
N120 G1 X4.7469
N122 G0 Z.1
Holding out hope this isn't one of those "Hey, look right here under your nose, DUMBASS." type problems.
:100 T1 M6 D0
N104 Z.1
N106 G1 Z-.015 F2.
N110 G1 X4.5935
N120 G1 X4.7469
N122 G0 Z.1
