tt12no
- Aug 24, 2008
- Northern Cal.
Hi,
The single block is active(light on) at all time(even when the toggle switch is in OFF position) on this Kitamura Mycenter 1 845 with Fanuc OM control( the machine only runs one block at a time in automatic mode.). I took out and checked the switch with the meter for close(ON) and open(OFF). That is a good working switch. Before re-installing the switch, I turned the power back on and notice that single block light was ON(active?) without the switch in place, and same problem too after putting it back. For getting the machine back to normal working, please advice me what to do. And as always, thanks in advance.
Best,
Best,
