evidence_UA
- Nov 23, 2015
HI, need to load the parameters on my Hitachi Seiki Vs50 with Sigma 18m controls (it's the same as Fanuc i18) but can't do it because it says that the memory write protection is enabled, however the switch on control panel is set to write and the "parameter write enable " on pmcprm is set to 1
My problem is I cannot change any option in settings menu (where there is an option "change parameters ") - all is set to "invalid ", and couldn't be changed. So the machine is kind of brick now
