Need lathe tooling suggestions for profiling on face (or a new strategy)
Results 1 to 17 of 17
    May 2005
    Napa, California
    1,040
    221
    99
    Default Need lathe tooling suggestions for profiling on face (or a new strategy)
    I'm looking for a single tool that I can use to profile the entire face of this part (6061). Kennametal has a boring bar that uses a 35 degree diamond (Kennametal part number A10SSVMBR2E), and has a -50 angle on the front. Seems like I should be able to rough out the 'outer' portion by plunging and facing on the +X side, leaving a cone of material around the hub that I can't reach while the spindle is rotating CCW, then reverse the spindle and use the same tool to remove the cone and cleanup around the hub while working on the -X side. I know the interrupted finish cut will leave a tell-tale line, but I can live with that.
    I saw that Mitsubishi has a new tool that uses a 25 degree diamond that may work even better than a 35 degree, still waiting on the sales guy for details. Anyone know of other boring bars that will get in there to work the face from both sides of X?
    This a gang tool lathe, and the part is on the large size for the machine, so I need to do this with one tool in order to have enough room to mount the other two tools necessary to finish the part (drilling type boring bar for the hub ID, grooving tool for the OD)
    FWIW, I could not find a face grooving tool that would do this job. Please ignore the tight radii on the drawing, I'll be opening them up as far as necessary.
    If you've got a better idea on how to do this, I'm all ears.
    Link to Kennametal boring bar type A-SVMB -5°: http://tinyurl.com/48jupb
    Attached Files Attached Files
    Sep 2008
    Ontario, Calif
    227
    57
    58
    Why not have a local tool grinding shop make you a couple of solid carbide tools or even alter existing inserts using your own design? At least you could profile it out in one shot. Whatever the face angle is you could have ground on the end of the tool, convex radii on both sides, with the space between the two being concaved. That way you could get a near perfect blend.
    Apr 2005
    Beaverdam, Virginia
    5,790
    201
    2321
    I remember seeing this, up for bid "S.F. bay area shops only", right?I think I asked a few questions and got no response, about 2 months ago. Doable with one tool out of a gang set-up
    pretty easy I would think, but your cycle time won't be the greatest. It depends on your round tool holding ability, clearance to the work face, your creativity. Probably best to post a picture or be more descriptive of the where the tool must go in relation to the work piece.
    Dec 2006
    Central Ky
    1,063
    51
    78
    When I do similiar work, I take a Kenametal VPGR turning tool and turn it parrallel to the z axis, and use it like a boring bar to "face bore". You would need a left and a right hand to reach the entire area. Vpgr inserts are available in a .007 nose radius if needed.
    Feb 2008
    Brisbane Australia
    1,048
    28
    88
    Btw, when I downloaded the drawing file my virus scanner detected a virus in the file.
    May 2005
    Napa, California
    1,040
    221
    99
    Quote Originally Posted by TonyOW31 View Post
    What virus scanner are you using? What does your scanner identify the type of virus as?
    The .pdf file was uploaded from a system using a fully up-to-date Norton protected computer. When I download, I get no virus warnings. Anyone else get a warning when opening?
    QB
    May 2005
    Napa, California
    1,040
    221
    99
    Quote Originally Posted by Dualkit View Post
    I appreciate the interest, but did not respond because of your location (bit too far from SF). At the time of my original post at rfq, I had other work, and did not want to take the time to figure out how to do this with my machine which is less than perfectly suited for the job.
    QB
    Oct 2006
    South Africa
    27
    Cool Face profiling
    I might be late to the party but I would strongly recomend tht you get hold of your local Iscar rep. They have all sorts of briliant face grooving bars that would do that profile no sweat.
    Feb 2008
    Brisbane Australia
    1,048
    28
    88
    Quote Originally Posted by Question Boy View Post
    QB
    I am using mcafee, it listed as a trojan.
    Mar 2003
    Utah
    1,057
    51
    15
    Face groove.
    Never try to machine stuff without the proper relief angles on your tooling.
  11. #11
    Feb 2006
    Republic of Texas
    2,252
    How about the A4 Groove and Turn system from Kennametal? Works for me.
  12. #12
    May 2005
    Napa, California
    1,040
    221
    99
    Quote Originally Posted by alphonso View Post
    I looked at that system, the narrowest insert in my catalog is .118". I can't open up the radii quite that much.
    QB
  13. #13
    May 2002
    South Central PA
    12,620
    1633
    2777
    I'm using McAfee also, no warning here.
    Do you update the definitions everyday? McAfee can be bad for false positives.
  14. #14
    Feb 2006
    Republic of Texas
    2,252
    QB
    I guess I don't follow what you want to do. The inserts come with corner radii from .008 to .047. Looks to me like face/plunging will allow you to profile the radii in your drawing.
  15. #15
    May 2005
    Napa, California
    1,040
    221
    99
    There is one inside arc greater than 90 degrees. Can't reach that with an insert that has more than one corner.
    QB
  16. #16
    Apr 2005
    Beaverdam, Virginia
    5,790
    201
    2321
    I must be missing something as the answer for a single tool appears simple to me. A solid carbide boring bar with the end ground to match the angle at the bore bottom should do the trick. Obviously the end will have to be thinned and additional clearance angles ground, it will
    work but you won't be setting speed records. Your programmed angle on x will have to match
    what is on the tool. I don't understand why you don't use multiple tools and just add another
    operation.
    One of these could be ground free hand, a link
    to a smaller version of what you need is here:
    http://www1.mscdirect.com/CGI/NNSRIT...41205&PMT4NO=0
  17. #17
    Aug 2005
    CT
    7,537
    248
    1542
    I'm guessing you only want to profile this with the single tool.
    Iscar does have incredibly nice facegroovers, but the full radius ones I think are like .118 wide, so neither inside radiis will happen.
    Thinbit OTOH does have nice facegroovers and they do make them down to .02 as standard.
    Don't have the catalog handy, but they may have a website to look at.
    I also think Circle offers facegrooving tools as well.
    Rouse-Arno is another one. I have one of their bar, which takes replaceable blades to match your requirement.
    And yes, I also would do this with a full radius facegroover.
