Need to level a Mori Sl-15 slant bed lathe. Don't have the turret plate
Community On The Web
Results 1 to 7 of 7
    viper is offline Titanium
    May 2007
    nowhereville
    3,722
    Default Need to level a Mori Sl-15 slant bed lathe. Don't have the turret plate
    How would a guy level this lathe without the special turret plate? I really need to get this taken care of but have no idea how to true it up at this point. I guess maybe stick a bar in the spindle for one axis? That does not seem like a smooth way to do it though. Thoughts?
    Tonytn36 is offline Diamond
    Dec 2007
    Southeastern US
    5,201
    Pull the covers off the back and put the level on the Z axis rails/ways.
    May 2007
    nowhereville
    3,722
    I will take a look on that but I really thought on the slant beds that the Z ways sit on a slant as well. Obviously the the X does.
    Ox's Avatar
    Ox
    Ox is offline Diamond
    Aug 2002
    West Unity, Ohio
    18,771
    Looks close enough from here.
    I am Ox and I approve this here post!
    Blue Steel is offline Stainless
    Sep 2007
    Adelaide Australia
    1,045
    Maybe use a pair of parallels clamped to the turret and put your level on those? There are machined surfaces there you can use as a datum.
    Stephen
    chip_maker's Avatar
    chip_maker is offline Stainless
    Jan 2006
    ct.
    1,136
    If one of your turret stations are parallel with the ground (12 o'clock) put a precision level on it and just level it that way.
    level it in the x and z direction, and then move it along the z to check for twist, should not be an issue for a small lathe like an sl-15.
    PBMW is offline Titanium
    Aug 2005
    Bremerton, Wa
    2,585
    don't have the plate for my SL10. I put the level on the top of the turret. Works a treat.
