Basically I need to cut foam sign boards much like Ultra Board's and I have zero experience.
It's panel consist of a rigid polystyrene face laminated on both sides (it's similar to cardboard)
The inside is closer to polystyrene foam.
I need to manufacture intricate cuts with minimum dimensions of 150cm x 120cm x 10mm (aprox. 60 inches x 48 inches x 3/8 inches )
These boards cut like butter with a sharpened blade, but quite frankly, it is not feasible for mass production by hand.
Can anyone recommend an inexpensive machine that meets the requirements of the dimensions?
I was thinking of some sort of router that can cut two boards double stacked. Or a drag knife, I'm sure you could increase the IPM with just a knife.
