the-machinist
- Oct 31, 2013
- North Carolina
Recently acquired a 1983 Pratt & Whitney Turnmate with Fanuc 6T controls. No stranger to Fanuc but never this old. It has an air chuck and air turret. Its wired up in a friends shop at the moment. Thus far I can get it to ref. return, turret indexes, both axis move smooth in jog, coolant pump runs, chuck opens and closes. I can't get the spindle to do anything nor can I get MDI to work, if I'm even doing it right, its different than what I'm used to. I switch to MDI and then press command button, I try giving it a G code or S with a number and what I'm pressing doesn't show up on screen. There were 2 programs still in machine, they look to be written correctly. I put in MEM and cycle start and it picks up everything fine, it gets to G50 S2500 and does fine, next is G96 S300 M3, and it freezes on that line, and cycle start button stays lit up green. Won't go any further than that. Spindle spins freely so I thought maybe it's not in gear, I tried putting M40 M41 M42 M43 one at a time in program and it froze up on those as well. I tried changing the G96 to G97, no change. The controls have spindle buttons CW CCW STOP, nothing happens. There is also CW and CCW inching, so I guess that is just jogging the spindle, still nothing. When I open up the back, I see the spindle drive unit/board, I see one green light and four white bulbs, so I have no reds all green. Behind that panel is magnetic contact switch and its enabled. I can see no blown fuses. There hasn't been any alarm codes or messages thus far. I've tried with chuck open and closed, and chucking on material with jaw travel about half way, still nothing. There has been a time or two, it doesn't do it every time, when I try to turn the spindle on, it sounds like it tries, I see the load needle go from 0 to 100 and then alarms out. But no alarm code or message, just says not ready. So I hit e-stop and pull back out and red light goes away. When it does that and I go around back, magnetic switch is out, after I reset, it makes contact again. Any help would be greatly appreciated, thanks in advance.
