I was recommended a Fadal 4020 i believe was the model. Would you know how that compares to the VMC15?
All I had worked on/owned was 4020s, and last year I bought an absolute cream puff VMC15XT from a member here.
I knew they were lighter, I knew it was made from weldments instead of giant castings. Linear instead of box,
which doesn't scare me. Its got about half the spindle power and no gear change, high to low is a change on
what windings are used in the spindle motor.
Compared to the 4020s, there are things I do have to take into account. Lower revs with a biggish twisty
drill.. Need to back off a bit or you stall it. It *sounds* different when getting busy. I really haven't
pushed it much... I bought it to do the little nit picky shit.. Work 3 weeks straight and can't even fill
a 5 gallon bucket with chips, that kind of crap..
A VMC15 isn't doing this.. at 18 cubic inches a minute.
OR THIS
But A VMC15 will make stuff like this.
and this.
It does great on smaller parts, cross holes, keyways, second ops. Moves aluminum fairly well also..
Its just not a huge HOGGING machine.. It'll move a decent bit, but you are going to like it much if you
are trying to pull 45 pounds off of a 70 pound block of 4340 (see pic #2)
Its a very capable machine within its limits.. I really like it..
All Standard Fadal disclaimers apply.
Its not a Mori, its not a Mazak, its a dirt cheap
commodity machine that can be very capable WHEN MAINTAINED.
Rapids are less than awe inspiring.
Tool changes will put you to sleep.
Cheap to buy, cheap to fix, my grandmother even
has one on her back porch, and parts are so
easy to find I think even the Pic Quik down the
street carries bellevilles.
They are what they are, but they are a lot of bang
for the buck, and more importantly, they are cheap
and easy to maintain and keep running.
