John Deere
- Nov 9, 2007
- The South
Man this file transfer thing is killing me!
Machine is a Daewoo 240MSB lathe with Fanuc 18i-t. First I tried using the RS232 and setting up with some instructions from Daewoo. No dice there.
Next plan was ethernet with Daewoo supplied instructions. They had me download TYP Soft FTP Server and so I did all that was outlined in the instructions and had file transfer relatively smoothly.
Now I can't make it work at all. I've rechecked everything in the instructions, etc with no luck.
What do you guys do for reliable easy file transfer? Do I need different software or what? I've used ProEZ on a Citizen in the past with good results, is that the plan.
All help is appreciated!
