gundog
Hot Rolled
- May 31, 2004
- Southwest Washington USA
I destroyed my second material height switch and at a cost of $395 I am not buying another one. I will back up a little I have a CNC router and it has a switch you set on top of the material that consists of a round switch with a plunger that runs normal closed when any tool in the spindle touches off to this switch set on top of the material it breaks the connection and there is a macro that determines the offset. This is my second in 3 years every so often it doesn't work and destroys the plastic plunger. I have decided to try a APM tool setter I found on ebay for about $120 has anyone tried one of these it says they are made in the US but the dial indicator it uses looks like an import? The old electronic switch was only repeatable to about .005" but good enough for what I do so I figure this one should at least match that. The tool setter is 3" long so a simple g92 z3 after I get it set is only seconds longer that the auto Z function on the control with the old crap switch. The machine is a Shop Sabre IS 510 with a 10 tool changer wine rack style. Control system is a WINCNC which is a decent control system it has been pretty much trouble free for 3 years except this material height switch. The machine has a dedicated tool height switch that is accurate and so far has been trouble free it is mounted to the tool rack at one end.
This is the one I bought APM CNC tool pre setter z axis touch off gage length offset height NEW
I did a search on here and did not find anything. I saw the Pro Tools one but I liked this one better because I can tilt the indicator to get a good view with the router it has a dust shoe that obstructs the view I am hoping this one is better for viewing.
Mike
Mike
