TeflonDave
- Sep 9, 2009
- NY, USA
I have a HAAS, Model TL-3W
With the HAAS control
Year- 2005
3.5 bore thru
This CNC is a Tool Room series lathe. Horizontal bed with CNC capabilities along with MDI and manual operation options.
It has a automatic transmission that is between the spindle pulley and motor. The spindle seal is leaking oil behind the pulley at about 1 drop / 5 sec.
Tech says that the whole Tranny assembly must be replaced with a factory built (or rebuilt) unit. Cost : WTFM
What I have heard and learned is;
1.The pulley is shrink fitted to the shaft (50mm dia).
2. By the book says that I will need about 700 degrees to loosen up. I have concerns about heat transfer into the tranny assy causing damage to other components.
3.The seal is right inside the aluminum housing that is right behind the pulley that is shrink fitted to the shaft.
4. The pulley is drilled and tapped to accommodate pull tooling the shaft has a center hole.
Anybody been there - done that before? Tips are greatly appreciated. Thanks
Year- 2005
3.5 bore thru
