I work with allot of families of parts.
When i shift from a part in say the 6" range to the 4" range i am usually off on diameters by 0.002-0.005.
What gives? Same tools, same inserts (We use Poly Crystalline Diamond inserts only, i do not believe it is possible to wear the pcd after 30 parts), nothing changing other than the major diameters. I am using tool nose radius offsets, but the parts is the same cross section only a different major diameter. If i change to a different part family the dimensions are off a bit more significant.
Am i missing something or is being off by 0.002" between different parts typical?
I fix the problem by changing the tool compensation, and life is good again.
