Rick Kight
- May 11, 2006
- Stone Mountain, Ga.
Hope someone can give us some direction with this. We are getting a alert #17701 ISUB Failure,
"manual tool change operation was aborted and did not complete" message at the end of axis alignment. Z and Y align but X never finishes.
I know the error scheme in there controls lacks especially when one error cause another. But looking at the error history this is the only error that is occuring. I do not know how a manual tool change error is happing at the end of the alignment. It looks like X finishes but does not register in the control. If you clear the error the control is saying " axis aligning" but X has stopped. Machine is not locked up, you can Data reset and can press the align axis button and it goes thru the alignment process again with the same results. any thoughts would be greatly appreciated. I am going to check limit switches on tool changer(spindle) and drum. Cycling power does not help.
Rick
Rick
