wozzwinkl
- Apr 19, 2013
- United States
Thanks in advance to anyone who can shed any light on this. I have done a fair bit of searching online and can't find anything.
I bought a used Nikken NX5 CAT 40 mount mechanical (planetary gear) 5:1 spindle speeder with max output of 20k rpm. Cooling is all by air.
I have no idea how old this thing is. It appears to be in good shape and runs smoothly.
I found a PDF manual that appears to be the correct one for my model at:
http://www.lyndexnikken.com/images/files/file/Toolholders-Instructions-Manual/Spindle Speeder.pdf
Page 13 of this document addresses heat generation, but the information they give leaves a lot to be desired. For instance, it says that you can run it at 18-20,000 rpm output for 30 minutes, but that you have to have a "cooling air blow" (they show this as an air stream directed at the body of the speeder). Presumably this means 30 minutes per hour, or 50% duty cycle.
My question is, how hot can this thing get? I am running a part that takes about 5 minutes, so I should be able to run several of these in a row before having to let the speeder rest. However, after even one 5 minute long part cycle, the speeder body is over 150 degrees F, even with the "cooling air blow". I have been using my flood coolant to pull the heat out by directing it at the speeder body (being careful not to get any coolant into the seal areas, and blowing excess coolant off gently before running it again), and I can get it back to room temp in about 3 minutes.
Before you ask, there is definitely grease in it.
Aside from the duty cycle that they give, there must be some kind of reasonable maximum temperature that this thing can be subjected to, right? I have a LOT of these parts to make at their 5 minute cycle time, so if I don't have to be waiting 3 minutes between cycles I can save myself a LOT of time.
Any input will be greatly appreciated!
-Jon
-Jon
