Rick_H
- Jan 26, 2013
- uk - midlands
Hi Guys.
In our shop we are CNC Mill only, no lathe - we don't usually do job-shop work but have been approached by a friend of friend with a job that I would consider to be definitive lathe work.
They need some circular inserts making - 70mm OD -0.00mm +0.05mm, concentricity is 0.01mm and this dimension is to be cut 15mm deep.
Material is 6061 Al- Other dimensions have no real tolerance.
If I take it on it would be for 2000pcs a year in 200pc batches.
We have a couple of less than year-old VMC's so wouldn't be making them on worn out iron.
Do we cut some bar-stock up and chuck them up on the machine or give it over to somebody with the lathe? I suppose the only reason I am questioning things is that I know they are currently being made on a lathe....
Thanks, Rick
Thanks, Rick
