A few weeks ago when I was setting up a job with 4th axis (HRT 210 a axis) for my vertical mill (Haas VM2) I experienced positional errors. When zeroing G54 the display would update to the right coordinates but the machine "wouldn't realise it". This happened several times for both y and z. After several restarts the machine would eventually go to the right coordinates. A few days went by and the machine sat powered off. I ran a few test cuts and everything seemed to be in order. The next day when I was about to start making the parts I realized that my G54 Z offset was had moved ~150 mm in negative direction even though the machine coordinate for the offset remained the same. After several restarts the machine would read the right coordinates and I was able to start milling the parts.
I haven't really had any more issues with the Z offset until yesterday when the machine crashed into the part and fixture. After about 20 finished parts the machine crashed in the middle of the program resulting in a scrapped part, tool and hydraulic holder.
