NPT thread dims? How do you program for CNC?
Results 1 to 17 of 17
    Aug 2009
    Saskatchewan, Canada
    241
    9
    132
    Default NPT thread dims? Edit: Chart Added
    I recently had to do a quick one off job cutting some external 1 1/4" NPT threads in some plastic. Rather than getting our programmer to do it offline, I figured I can just hand write a simple program at the machine.
    Since it was plastic, I figured a quick turning path to produce the taper, and then thread it. I then spent an hour scratching my head and trying to calculate what diameters to turn the material to and what coordinates to program the threading too. The Machinery's Handbook gave me pitch diameters and I faked it from there until it fit since it wasn't a critical part.
    It got me thinking, there must be an easier way to figure this out. How do you guys do it? It's there a chart our there or formula I can use to figure out my programing points? I hate spending an hour doing calculations just to cut some simple pipe threads. All our pipe thread is usually programmed offline so I've never really had to do with it before.
    Any help is greatly appreciated.
    Aug 2005
    CT
    7,532
    248
    1539
    One of the best money ever spent is this piece of software:
    ThreadPal
    If it has to do with threads, you will get it exactly!
  3. Likes roysol, lonestar1224 liked this post
    May 2011
    4,391
    599
    1793
    +1 on thread pal. You can eaven change the size wires and figures it for you.
  5. Likes lonestar1224 liked this post
  6. #4
    Aug 2009
    241
    9
    132
    I downloaded the trial verison of Threadpal. Great little program but I'm not paying $100 for a program I'll only use once or twice.
    I drew up a little diagram in Solidworks and I'm just punching in the numbers and making up a chart. So far my numbers match up with the Threadpal, so I'll just do it that way.
    I'll post the chart when I have it done so others can use it.
  7. Likes EnderDRM liked this post
  8. #5
    Aug 2005
    CT
    7,532
    248
    1539
    Quote Originally Posted by Armedsask View Post
    Suit yourself.
    But when the inspector comes calling with a thread dim being out a few tenths that you didn't even know about, I bet Threadpal becomes wicked cheap in comparison.
  9. Likes Bobw liked this post
  10. #6
    Aug 2009
    241
    9
    132
    Like I said in my initial post, this is for jobs that are quick and dirty one offs, like some guy just wanting pipe threads cut for some project. Tolerance is checked with the corresponding fitting, not a gauge.
    There is no inspector for what I'll be using this for.
    The following chart was created using the data from the Machinery's Handbook. The only numbers I came up with were the Major Diameter at Face (D2), Minor Diameter at Face (D3), and Length of Taper (L2). These were done by drawing the pipe in Solidworks and plugging in the different numbers.
    I make no guarantees as to the accuracy of the following chart. Use at your own risk.
  11. #7
    Apr 2017
    NETHERLANDS
    8
    So how did this end?
  12. #8
    Feb 2013
    Madison, WI
    673
    870
    418
    If you're going through the troubles of drawing it up in Solidworks, why not just program it offline? It should be just as fast.
  13. #9
    Apr 2017
    NETHERLANDS
    8
    here is I think a nice description of what you have to face when cutting a NPT tapered thread
    Using
    Notation
    H = 0.866025p = height of 60deg. sharp V thread
    h = 0.800000p = height of thread on product
    p = 1/n = pitch (measured parallel to axis)
    n = number of threads per inch
    a = 30deg. = thread flank angle
    ß = 1deg. 47 min. = thread taper angle for 1/16 taper
    fc = depth of truncation at crest
    fr = depth of truncation at root
    Fc = width of flat at crest
    Fr = width of flat at root
    Technical Specifications for NPT Taper Plug and Ring Gauges
  14. #10
    Nov 2002
    3,029
    1337
    648
    Here is a good starting point for your data needs. Beyond that, ThreadPal!!!npt-chart-2.jpg
  15. #11
    Dec 2011
    Whitehall, MI
    543
    112
    131
    You can figure everything you need out from the Machinery's Handbook, although it seemed it was about as clear as mud. But you can get there.
    For your situation my best suggestion would be to make a program for each size you are going to do, and just keep those in your machine memory. I did kind of the same thing, but with Mastercam programs since I have access to that.
  16. #12
    Apr 2017
    NETHERLANDS
    8
    Quote Originally Posted by AARONT View Post
    Interesting suggestion: do you have to understand how to manually turn this tricky thread on let's say a conventional lathé or would SolidWorks solve the headache for you?
    The other interesting question would be: why would you need Tread(Pay)Pal besides an expensive SolidWorks licence? You would expect that SolidWorks would support NPT thread anyway?
  17. #13
    May 2015
    Tennessee
    130
    47
    59
    I don't know what CAM software you might use, we use SolidCAM. When I model the part, I draw the taper into it and it will guide the tool on that taper. I think the angle is 1.783 degrees from centerline.
    The length is determined from whatever specs are given either by the print or online information, and of course the upper diameter is the O.D. of the pipe.
    CAM software makes it easy, automatically putting out the correct I value for thread taper. You would have to trig out the dimensions if you were coding it at the controller, allowing for extra Z and accounting for that in your I value. I believe the I value is negative for an O.D. right hand tapered thread.
  18. #14
    Feb 2010
    Washington State
    392
    528
    142
    UN imperial screw thread calculator
    This guy doesn't have pipe thread, but he has a few other interesting calculators.
  19. #15
    Aug 2005
    CT
    7,532
    248
    1539
    Quote Originally Posted by Spixy View Post
    I don't speak Aland Islandian, so can someone please interpret this for me?
    The fact that Solidworks ( or whatever CAD ) supports NPT threads is pretty fucking meaningless when you program and then measure the finished product.
    ThreadPal tells you what to measure to what tolerance and even gives you a good starting point as to how.
  20. Likes Bobw liked this post
  21. #16
    Feb 2005
    8,373
    11512
    9382
    I put off buying threadpal for years.. It was on my "to do" list, but I just never got around to
    it.. Then one day I had a bunch of oddball threads to do... 11/16-20 UNJ type of threads...
    It paid for itself with in a week.. I never had to calculate anything, I didn't have to find the
    formula for thread wires, I didn't have to find a machinery's handbook, I didn't have to figure
    out where I left my copy of the J thread spec, I didn't have to go googling looking for a chart for
    form taps....
    Just open threadpal, type in your thread and *BAM*!!!! Everything you could possibly need to
    know about that thread is right in front of your face.. 30 seconds tops. It even prints
    all the goodies out in a nice report form for you that you can put in the pile of paperwork
    to send off to your customer.
    I'd say its one of the best investments I've made, its paid for itself in saved time many times
    over and its fricken CHEAP, I think $80 or so when I bought it, its $100?? now.. Worth every
    penny.
  22. #17
    Jan 2005
    CANADA
    Saskatchewan
    9,430
    1138
    3174
    Quote Originally Posted by Job Shopper TN View Post
    That's all fine, but doesn't help you measure the part on the machine. You need to measure the pitch diameter of the first couple of threads and need to know what figure you're trying to hit.
    I made a few of the larger pipe threads as gages many years ago. I used MH data to figure out the PD, which I measured using the 'two wire' method.
    Even having gages doesn't always get you what you want: I have a customer who wants his pipe threads left oversize to accommodate his china made fittings which are (unsurprisingly) tapped too deep on the gage.
  23. Likes Bobw liked this post
