Okuma l400 lathe
shagdriver
Dec 6, 2017
How do I use the constant subtract offset for the x axis ? I am taking .01 passes on a pulley die, and would like to use some of the auto features on this lathe. (fyi - I'm new to the okumas) If I can't do it w/the offset page, how would I loop the program ?
On the offset page: Add -.01
To loop a program, there are a couple of ways. But the easiest is to make a sub program.
On the Okuma, the sub program needs to be at the end of the main program after the M02/M30 code.
Call your sub O (the letter O) followed by 4 letters
OLOOP for example.
Put the sub call in the main program where you want it.
To loop a sub: Call OLOOP Q10 (to loop 10 times)
At the end of the sub put an RTS
Main program
Sub call
M02
Sub
RTS
