rnmmhunter
Cast Iron
- Oct 2, 2012
- Menomonee Falls Wi
Can someone tell me how to edit the speeds of this program? I didn't write it looks Greek to me.I run a Fanuc controller.The boring bar starts at N0400 I would like to slow it down and there is no G50 where do I put it?
$L531028.MIN%
N0001 ()
N0002 ()
N0003 ( "L-2 ONLY" )
N0004 (REVISED ON 06/05/10 J.J.)
N0005 (1.250" DIA. BORE ID SIZE)
N0006 (INSTALL P/N 999-102 JAWS)
N0007 (X ZERO SET TO BE 559.040)
N0008 (Z ZERO SET TO BE 283.740)
N0009 (MAT:....ALUMINUM CASTING)
N0010 (MACH. BASE 1ST,THRDS 2ND)
N0011 (PROGRAM IS AT PEAK S.F.M)
N0012 (CYCLE TIME:3 MIN.23 SEC.)
N0013 PO=.1800 (0 SHIFT, SIDE 2)
N0014 CLEAR
N0015 DEF WORK
N0016 PS LC,[-20,00],[20,21],4
N0017 PS LC,[-09,00],[09,27],4
N0018 PS LC,[-20,00],[20,11],0
N0019 PS LC,[-20,00],[11,14],0
N0020 END
N0021 DRAW
N0022 G50 S1200
N0023 M216
N0024 M01
NAT02 (55 DEG. TURN & FACE TOOL)
N0200 G00 X20 Z20 G95
N0201 G97 M03 S1200 M42
N0202 G00 X2.75 Z.1 T020202
N0203 G96 S600 M08
N0204 G00 Z.02
N0205 G01 X.95 F.005
N0206 G00 Z.05
N0207 X2.75
N0208 Z0
N0209 G01 X.95 F.005
N0210 G00 Z.05
N0211 X2.65
N0212 G85 N0213 D.125 F.012 U.025 W0
N0213 G81
N0214 G00 X2.4
N0215 G01 Z0 F.01
N0216 X2.5 Z-.05 F.003
N0217 Z-1.015 F.008
N0218 X2.292 F.005
N0219 G04 F.25
N0220 G01 X2.6 F.2
N0221 G80
N0222 G87 N0213
N0223 G00 Z.1 M09
N0224 G97 S1200
N0225 X20 Z20 M05
N0226 M01
NAT04 (1.0" DIA. BORING BAR)
N0400 G00 X20 Z20 G95
N0401 G97 M04 S800 M42
N0402 G00 X1.125 Z.1 T040404
N0403 G96 S335 M08
N0404 G85 N0405 D.1 F.012 U.025 W.005
N0405 G81
N0406 G00 X1.35
N0407 G01 Z0 F.01
N0408 X1.250 A225. F.003
N0409 Z-.925 F.008
N0410 X1.225 F.1
N0411 G80
N0412 G87 N0405
N0413 G00 Z.1 M09
N0414 G97 S800
N0415 X20 Z20 M05
N0416 M01
N0417 (********************************)
N0418 M00 (***** [FLIP PART OVER] *****)
N0419 (********************************)
N0226 VZSHZ=PO
N0227 CLEAR
N0228 DEF WORK
N0229 PS LC,[-20,00],[20,20],4
N0230 PS LC,[-13,00],[03,27],4
N0231 PS LC,[-20,00],[20,14],0
N0232 END
N0233 DRAW
N0234 G00 X20 Z20 G95
N0235 G97 M03 S1200 M42
N0236 G00 X2.8 Z.1 T020202
N0237 G96 S600 M08
N0238 G00 Z-1.02
N0239 G01 X1.99 F.005
N0240 G00 X2.8
N0241 Z-1.048
N0242 G01 X1.99 F.005
N0243 G00 X2.8
N0244 Z0
N0245 X2.1
N0246 G01 X1.225 F.005
N0247 G00 Z.05
N0248 X2.0
N0249 G85 N0250 D.1 F.012 U.025 W0
N0250 G81
N0251 G00 X1.455
N0252 G01 X1.575 Z-.06 F.003
N0253 X1.66 Z-1.05 F.008
N0254 X2.45 F.005
N0255 X2.5 Z-1.1 F.003
N0256 Z-1.435 F.008
N0257 X2.292 F.005
N0258 G04 F.25
N0259 G00 X2.65
N0260 G80
N0261 G87 N0250
N0262 G00 Z.1 M09
N0263 G97 S1200
N0264 G00 X20 Z20
N0265 M01
NAT10 (O.D. 60 DEG. THREAD TOOL)
(1 1/4"-11.5 NAT. PIPE THREAD)
N1000 G00 X20 Z20 G95
N1001 G97 M03 S500 M42
N1002 G00 X1.75 Z.1 T101010 M08
N1003 G71 X1.475Z-.92A178B60D.02U.002H.07F1J11.5M22M32M73
N1004 G00 X1.75 M09
N1005 Z.1 M05
N1006 X20 Z20
N1007 M215
N1008 V2=V2+1
N1009 M01
N1010 M30
$L531028.MIN%
N0001 ()
N0002 ()
N0014 CLEAR
N0015 DEF WORK
N0020 END
N0021 DRAW
N0022 G50 S1200
N0023 M216
N0024 M01
N0203 G96 S600 M08
N0204 G00 Z.02
N0206 G00 Z.05
N0207 X2.75
N0208 Z0
N0210 G00 Z.05
N0211 X2.65
N0213 G81
N0214 G00 X2.4
N0215 G01 Z0 F.01
N0217 Z-1.015 F.008
N0218 X2.292 F.005
N0219 G04 F.25
N0220 G01 X2.6 F.2
N0221 G80
N0222 G87 N0213
N0223 G00 Z.1 M09
N0224 G97 S1200
N0225 X20 Z20 M05
N0226 M01
N0403 G96 S335 M08
N0405 G81
N0406 G00 X1.35
N0407 G01 Z0 F.01
N0409 Z-.925 F.008
N0410 X1.225 F.1
N0411 G80
N0412 G87 N0405
N0413 G00 Z.1 M09
N0414 G97 S800
N0415 X20 Z20 M05
N0416 M01
N0226 VZSHZ=PO
N0227 CLEAR
N0228 DEF WORK
N0232 END
N0233 DRAW
N0237 G96 S600 M08
N0238 G00 Z-1.02
N0240 G00 X2.8
N0241 Z-1.048
N0243 G00 X2.8
N0244 Z0
N0245 X2.1
N0247 G00 Z.05
N0248 X2.0
N0250 G81
N0251 G00 X1.455
N0254 X2.45 F.005
N0256 Z-1.435 F.008
N0257 X2.292 F.005
N0258 G04 F.25
N0259 G00 X2.65
N0260 G80
N0261 G87 N0250
N0262 G00 Z.1 M09
N0263 G97 S1200
N0264 G00 X20 Z20
N0265 M01
N1004 G00 X1.75 M09
N1005 Z.1 M05
N1006 X20 Z20
N1007 M215
N1008 V2=V2+1
N1009 M01
N1010 M30
