Depends on what you mean by "tube". Also depends on the tolerances you require. Oxy-fuel doesnt have the control, especially on small stuff, that laser does. So if you are doing precision on 1/2", then you are pretty much stuck with laser. Might be a waterjet system out there?
Most of the plasma and torch, models are for larger diameters- 2" and up usually.
For smaller stuff, its usually either done with a laser, for the precision, or done mechanically.
IE, with a shear setup, either freestanding or tooling that fits in some kind of press, or sometimes even with abrasive belts.
Assuming you want big,
these guys make a plasma model, made in USA.
http://www.vernontool.com/pagesnew/mastertubeplasma.htm
Heres one, think its from Taiwan, should be cheaper-
http://www.advancedfab.com/PlasmaCope/PlasmaCope.htm
You really ought to get the Tube and Pipe Journal, if just for the ads. Its free.
http://www.fma-communications.com/TPJ/TPJ.cfm
Most of the industry advertises in it.
also, this is good site-
http://www.tubenet.org/main.shtml
