Gosiger finally got to me on this issue. changed NC Optional Parameter Bit N0. 70 bit 6 rotary axis with limit or without (check box)
They sent this .doc
SYNC SCALES: CAL X, Y, Z scales with encoders in System Parameters
Multi Turn Function (Do not use for simultaneous)
NC Optional Parameter Bit No 39
Bit 3 A-Axis to 1
Bit 4 B-Axis to 1
Bit 5 C-Axis to 1
* Short connection for rotation direction ( Replaces using M15 M16)
*NC Optional Parameter Bit No 69
*Bit 0 4th-Axis to 1 (B-Axis on HMC)
*Bit 1 5th-Axis to 1
Bit 2 6th-Axis to 1
After reset or Power on the rotary axis will always use shortest connection between 2 positions with M15 and M16 we can control CW or CCW.
Short cut by M-Code for MB-V form Jan 2005 and MA-100H from April 2005 Production.
M403 : 4th-axis
M404 : 5th-axis
M405 : 6th-axis
*NC Optional Parameter Bit NO. 15 bit 7 (inch mode use F as feed rate for rotary axis)
*For MU simultaneous machining, set A and C axis to modal in parameters. Stops automatic axis brake. (Uncheck boxes for brake modal and check boxes to use M code for brake). Parameter page-Additional Axis.
NC Optional Parameter Bit No 54
Bit 2 - Inverse Time to 1
NC Optional Parameter Bit No 67
Bit 5 – Accel Low Vibration Mode to 1
NC Optional Parameter Bit No 46
Bit 0,1,2,3 – Rapid Interpolation for GOO, G30, G60, Home Movement to 1
