Jay Fleming
Hot Rolled
- Aug 7, 2014
- Noble, OK
I found the 24vdc power supply to be bad on my lathe that is due to be shipped to another forum member tomorrow morning. We've worked it out about not needing it fixed today but is it possible to repair them, assuming you know exactly what's wrong, or is there an alternative to Okuma to purchase a new replacement? Of course, ebay has used, so that may be the only option.
On a side note, I found a mouse nest in the operator panel of the lathe while diagnosing the power supply. I'm assuming some of the nest, along with piss, may have shorted the power supply out, not so much to blow the internal fuse but maybe damage another component within the power supply. Is there a common weak link in these power supplies to key in on?
