Results 1 to 17 of 17
    stampyoldani is offline Junior Member
    May 2005
    Oakland
    22
    Post
    Hi all,
    After many many delays I'm finally about ready to purchase a "hobby" mill. Its got all the features I'm looking for, and I think its reasonably priced at 13K(well the upper end of 'reasonable' at least). But before I jump in I thought I would check it out here to see if I'm way off base (on price, and quality of hardware/software).
    Machine has less than 400 hrs, 30 taper,3 second power drawbar, some tooling included, heidenhain TNC 310 Control, with rs232 port,Baldor variable frequency motor control, 1 phase or 3 phase, 3 hp motor.Automatic way lube.
    I'm in northern california and the machine is near my shop.
    Any comments are welcomed.
    Dave K is online now Diamond
    Mar 2004
    Waukesha, WI
    4,803
    Post
    Well, I am certainly no authority on equipment for hobby use, and don't have much experience on anything less than a full machining center. Having said that, take my opinion with a grain of salt. If I were looking for a machine for the use you describe, I would think that looks like a fine deal. Not really a steal, but not really a rip off either.
    My bet is Don will have the most experience with proper pricing of equipment.
    Milacron's Avatar
    Milacron is offline Diamond
    Dec 2000
    Coastal Dogpatch, SC, USA
    41,119
    Post
    Looks like a good buy to me. Very unusual to see a Heidehain control on a Tawainese machine, but this is a good thing, as the 310 is still a current model and an excellent control. That control panel alone (i.e. no drives, motors..just the control panel) sells for $9,000 new.
    Mebfab is offline Diamond
    Jun 2003
    Mebane North Carolina USA
    4,841
    Post
    I have a slightly older version of that machine with a dead Centroid control. About to start a PC retrofit.
    Dualkit is offline Titanium
    Apr 2005
    Beaverdam, Virginia
    3,646
    Post
    Answer a few questions and I will give my opinion. What year is the control? How many
    programmable spindle speeds, are they reversable,
    and what is the knee travel?
    bcstractor's Avatar
    bcstractor is offline Stainless
    Apr 2004
    Monument CO USA
    1,904
    Post
    We've been looking for something similar for our work model shop. This is at the low end on pricing.
    Nice - pity it's not in Colorado or I'd send the boss over.
    Chris P
    Milacron's Avatar
    Dec 2000
    41,119
    Post
    Zero
    May 2005
    Oakland
    22
    Post
    9"x42" table, 30" X travel, 12" Y travel, 16" Z travel
    I'll have more details about the age of the control and such on monday.
    I haven't seen the machine first hand yet, but I have some experience with a sharp knee mill and it seemed very rigid, the whole head of this machine moves vertically for the Z travel, and it looks to me that it would be more rigid than having the knee move.
    I say "hobby" because I am not a super hardcore CNC machinist that is going to require maximum productivity from this machine. I am a relative novice, and I will be using the machine to learn on and to fufill modest requirements for my small engineering and fabrication shop. I understand that many would reccomend a VMC, and maybe one day I will be able to upgrade.
    Anyone have any gripes about hte reliability or useablitiy of the heidenhain controll? at 9k for a new interface, I'd hate to hear they had lousy customer service and were habitually faulty.
    I really do appriciate all of the feedback! Keep it coming.
    Hansdie's Avatar
    Hansdie is offline Hot Rolled
    Jul 2005
    San Francisco, CA
    652
    Post
    Well to answer Dualkit first;
    What year is the control? ~1999-2000
    How many programmable spindle speeds? variable 0-4000
    are they reversable?yes
    and what is the knee travel? no knee its a bed mill.
    To answer Stampyoldani;
    I wouldn't call this a hobby machine at all. The TNC 310 is a super reliable control only problem I have ever seen is a little LCD burn in from a customer that left the control on 24/7 for years.
    As far as useability the only limiting factor, I feel, is block processing time for 3D contour milling (I.E thousands of lines of .001 movement).
    Heidenhain service and support of the control is good.
    Also that machine uses linear scales on all 3 axes making it much more accurate and repeatable since its a true closed loop.
    Apr 2005
    Beaverdam, Virginia
    3,646
    Post
    The same thing new appears to be about $22,000
    in some of the catalogs I have looked in, I would
    try to get it for 1/2 of that $11,000 for starters. If you don't want all the bells and
    whistles. Mid 80's 3 hp Laguns, 3 axis, without
    the programmable spindle, with the same table
    travel, can be had for $3500-$4500.
  11. #11
    fredj is offline Member
    Jun 2005
    59
    Post
    As soon as you get it make a backup of all the parameters.
    I know for a fact that if you use the com port on the
    TNC310 control you can send in bad code
    in a porgram that can and will crash the control.
    Teh reason i say this is I have some problems with my post file for Gibbs
    and some times the program sent into the machine
    will crash the controls eprom
    Now I am back to reloading the control parameters
  12. #12
    May 2005
    Oakland
    22
    Post
    ooh that is a bit scary, I am planing on using Mastercam to generate much of my code (from solidworks files). I was hoping that for some parts I would be able to drip feed programs directly from the computer into the running machine.
  13. #13
    keithg is offline Senior Member
    Mar 2005
    410
    Post
    Fredj: I would suspect there is something besides a bad code, I have had problems similar with my 310 with ground loops or a bad power supply.
    Back up the parameters, also the plc
    the 310 is not as beefy as other heidenhains, but still better than most
  14. #14
    SIM
    SIM is offline Stainless
    Feb 2004
    Staten Island NewYork USA
    1,945
    Post
    Two thoughts.
    I have had some experience with "Sharp". Parts where pricey and not readily available. The few parts I did get required modifications to work properly. Not being a hobbyist, I can't wait a few weeks till someone gets around to shipping a part that "should" work.
    At 13K I would pass due to the lack of Rigid Z travel and Auto-Tool Changer. I would also pass at 1/2 that price for the same reason.
    However, if machine fits your needs it doesn't appear abused and its clean.
  15. #15
    Hansdie's Avatar
    Jul 2005
    San Francisco, CA
    652
    Post
    Fredj- Which software version are you running? I've never had the problems of parameters get erased, unless the battery is dead and the machine sits for a while. Also of course you should have hard copy backups of you PLC and MP list. But both of these can also be stored permantently onto the Eprom.
  16. #16
    May 2005
    Oakland
    22
    Post
    I gave it a first look today, The machine was clean, and looked ot be in good shape, but it hadn't been used much in the last 2 years. It has some sort of baldor variable freq. drive unit. It looks to be a very good feature, and useful for my shop as it will adapt the freq to run off of the 220 single phase that I have. But it makes a whiny noise at low rpm. The spindle sounds good, with just a quiet whirr at high rpm. The tool changer was quick and a nice feature, the vertical travel is assisted by that air cylinder thats on the side of the machine for really smooth travel. It has a place for a 4th axis board in the controls. and It has fully programmable spindle speeds and coolant,although the coolant plumbing was missing.
    Overall the machine looked good, I was a bit dissaponted that the only inputs appear to be either manual programming, or by the rs232.
    I borrowed the programming manual and am going to learn a bit about the control so I can prepare myself to check the machine more thoroghly later this week.
    It seems like the consensus is that it not a horrible machine, but could get expensive to service. which makes me a little nervous although the machine really appears to be in excellent condition.
    At this point my major holdup is that I need to figure out the controls.
    Keep it coming, I appriciate the feedback.
  17. #17
    Mar 2005
    410
    Post
    The machine can hold about 6000 blocks of program, so drip feeding may not be required[?], as long as you don't try to hold too many in the machine
    Heidenhain service is the best in the business. They swapped my control via UPS red label when my 24v supply fried it,I had it in the next day and running. They billed me when the repaired my unit, cost ~1200 bucks IIRC.
