OSG Mega Muscle Drill Video
ewlsey
Jul 14, 2009
Peoria, IL
I'm not in love with the name, but it is impressive. They claim 1.5 to 2 times the chip load of a standard carbide drill.
The real fun starts at 2:50 when they drill 6.8mm holes in cast iron at 650IPM.
Wow
For 4140 steel with 10.3mm drill
I am only getting
SFM: 175 f/min
RPM: 1649
APT: 0.00424 in/rev
Feed: 20.96 in/min
MRR: 2.7 in^3/min
HP: 1.8
Torque: 68.4 in-lb
Breaking Torque: 94.9 in-lb
Their feed should generate 116.7 in-lb of torque...
Heh and someone was saying my calculator was crazy.....
Seriously they are showing 170% Feed any sane person would ever recommend. :crazy:
....waiting for the 'its only cast iron' comment....
seriously though, I've crashed drills at slower speeds!
I liked the part where they drilled the holes.
"Mega Muscle Drill"? Well it is from Japan so that sounds about right.
I don't have enough coolant flow or fixture support for a drill I am using from Dormer, in al, now sandvik R587. Their starting feeds and speeds were mach f'ing booking and mach f'ing booking... I settled at 7000 and 120ipm. Which at a 10.3mm diameter ain't too shabby, less than half their recommended feed, but this is mostly due to the lack of support on the fixture. That being said, I find what they are doing in Iron to be a bit obsurd... ie .024 per tooth.. I don't see how a 6.something mm drill can handle that once it dulls up a little bit...
