HuFlungDung
- Jan 19, 2005
- Canada
I was chasing down a slight bearing howl in the head of my VF3. The noise occurs after the machine warms up and is running somewhere above 1000 rpm. The sound does not really become more intense with speed increase, it either howls or it doesn't.
I removed the belt from the transmission, and it seemed as though the noise disappeared, with only the motor and transmission running.
I hummed and hawed over whether I should just "do it" and buy a factory remanufactured unit ($2900 Cdn) or try it myself. Part of the reason I wanted to do it myself, is because I'm not dead sure that the problem is in the spindle. Plus, I was dying to see what was inside
So, guess what I decided?
I got the old cartridge apart without wrecking anything. It is a different assembly method than I have seen before. Basically, everything is permanently assembled with heat shrink collars. While not very user friendly to take apart and put together, I guess that the collars would have the benefit of holding the races very parallel to one another. I had experience with another machine that someone had rebuilt, and they had overtightened the bearing retaining nut and actually produced some runout of the spindle!
Everything is a wee bit on the loose side, yet it doesn't appear to be worn loose. The lower pair of angular contact bearings have a half thou clearance in the housing, as do the upper set. I would have thought that the main angular contacts should be an "on size" sort of interference fit.
One of the old bearing inner races is also a slip fit on the spindle. The other one seems closer to size on. I don't know firsthand if there is enough pull in a 1300 lb drawbar to actually expand the mouth of the spindle by a half thousandth. I did read a warning somewhere in the Haas service cd that running the spindle without a toolholder in place was detrimental to a new set of bearings.
The original A/C bearings and spacers are all serialcoded to be a matched set of Barden bearings. The inner spacer is a full .001" shorter length than the outside. Before disassembly, the bearings did roll over with a light preload. However, inspection of the inner spacer and bearing races shows me that there was some relative spinning going on between the spacer and the bearing, so the preload collar was not clamping the inner races tight against the spacer. Could this be the cause of the howl?
I ordered new bearings flush ground with a light preload. I plan to lap the outer spacer to the same length as the inner spacer. I don't know if light preload is enough, but I am wary of getting the thing too tight, because I like to run it fast more than slow.
My plan is to carefully loctite the inner races of the a/c bearings to the spindle. Same in the housing. By careful, I mean so as to not have an excess of that crap running around causing trouble. A wee bit of loctite near the back shoulder and a wee bit on the outer race of the front bearing as I slide it together. The upper bearings will not be loctited whatsoever, as I realize they must float.
When all assembled, then I plan to regrind the taper a wee bit. It was bruised a bit anyway, but I didn't do it! This will be done on the lathe, holding the front nose of the housing in the steady rest, while driving the spindle with the chuck.
Comments by those who have tried this themselves are welcome. Also, from the pros, of course.
