MacDaddy
- Jul 23, 2014
- Ontario,Canada
I think I know everything but in case I don't - somewhere in my convoluted mind I am sure that when G43 and an H value are programmed, somewhere in the parameters it inputs the length value of the associated tool so calculations can be made for movements.
Is this a correct - and would anyone no the parameter number? I have looked through a couple of manuals I have but no luck.
My dilemma is I use 3 tools to do machining on parts on a Mori Seiki with a pallet change system.
Each tool does 2 parts and then times out and moves on to the next - all not relevant.
At the end of the cycle before tool changing I have a sub program to verify tool length on a Blum laser and if it is off because of chipping or breakage then the machine alarms out.
The sub program needs the tool 'H' value to conduct its measuring cycle.
I need to either find the parameter value so I can put in H#5200 (example) so it will use whichever tool is in - or i will need to right a macro and use 3 sub programs for the different tools - which then I will probably need to find the variable for the 'T' value.
As an aside in case anyone has similar machine - to call up the tools with an M06 I use T9901 (01 is the group it selects from in the tool management) and where G43 is I need to put H9999.
I tried putting H9999 in the sub program but it says "Variable out of Range".
Any help appreciated.
