I have a VMC that I've owned for 6 years and a part I've been making for years also out of acrylic.
I machine the back of the part, then mount on a fixture and 3D profile the front to something of an egg shape. The last pass is with a 1/4" ball endmill and a 1/16" stepover to give sort of a crosshatch pattern on the front. I do this back-and-forth operation in 2 directions offset 90 degrees to each other leaving the surface of the part looking almost knurled.
I run this job occasionally, and sometimes one of the parts will work loose on the fixture and get a crappy finish - no biggie, I run 20+ at a time and if I lose one it's not a huge problem. I have 10 different programs with different shapes/sizes of these parts, all very similarly made. But lately, on some of the parts, I am getting horrible finishes on 10 or 12 of the parts from the finishing pass.
It looks like 1 or 2 of the cross-hatch finishing moves with the ball endmill will be 1/16" lower than the rest, leaving a groove in the part. And somtimes it looks like the tool only touched the part in the X direction crosshatch cut and didn't even touch it in the Y - so instead of a crosshatch I get just parallel lines. Sometimes half of one part will have the correct crosshatch and the other half will just be grooves in one direction - looks like the ball mill stopped making contact with the part half way through the second crosshatch cutting portion of the program.
The weird thing is that it appears to happen repeatably in the same places on the same parts in the fixture. I can run 10 parts and #3 (for example) will always have maybe a groove that's deeper than the rest always in the same place on the part. I have other parts that work fine and always give a beautiful finish to every part on the fixture (and we're talking the SAME fixture!).
I am trying to figure out what could be going on to cause this. Given it's the same fixture and same feed/speed, I thought it has to be the programs - but those haven't changed at all in years. No settings have been changed on the VMC either, nor have any coordinate systems been changed. I wouldn't think it's anything mechanical on the machine because it happens in the same places on the same parts but other parts in the same vise in the same spot on the machine will come out perfectly fine. I've made sure the vise is tight and secure, changed out the finishing tool, made sure my fixture is good, checked backlash in the Z axis on the machine. All were fine.
Any ideas what else to check or what the hell might be going on here? Tool coming loose in the holder maybe? Drawbar issue? Doesn't seem like those since it's so repeatable.
