I have found that the parting off the bigger diameter SS's that by the time you get to center, the material must be getting pretty hot down in there. Have had lots of trouble on one certain 2" job once. But on a smaller D material - not so much trouble.
I backed off on the finish cut. I started cutting off to maybe .100" and then twist it off with the sub-spindle.
Another option is to break it off by hand.
Another option is to even break it off with the turret somehow.
I have my Top Cut on the barfeed macro set to cut to .100 as well. Then the trigon just breaks it off when it makes the face cut.
My broken cut-off issues have gone bye-bye after these two changes.
I understand that if this is set just right, and the coolant is just right, and the nozzle doesn't get whacked out of the way, and if ... , and if .... , then you shouldn't have these troubles...
I found a way to not have the troubles in less than ideal conditions.
Think Snow Eh!
Ox
