If you are using G28 U0 for X-homing, it is system A.
A, B, C apply to lathe only.
Now you are confusing me. Both the 0m-mate and 18mc use G28 X.Y, Z. So what system do I have?
I believe 99% use system A, and remaining use B or C. Am I correct?
Any major reason for using B or C?
For example, G28 U0 would alarm out in B and C where G91 G28 X0 is needed.
@ Europe:
A versions are most common, what I know.
B versions for e.g. Lathes with Live tools. e.g. Fanuc -TB
C versions, never seen in a machine shop, but we use it at our school. (duh)
Difference of Lathe A and B version is G98, G99. A-version lacks it.
The C-version we use at school, might just be for the Emco switchable control ability,
or just their 'fancy' way of design. Im used to A and B, so C is just confusing.
So, those Fanucs that I encountered, are 65% A, and 35% B.
You are confusing control revisions with the g-code system.
Hello mikiemus,While our Lathe Fanuc 21, with C-list, performs G28 U0 perfectly. (G28 X0 makes it go X0, then X-home. like double move)
(parameter settings could fool anyone, to be too certain)
System A has G98/G99 commands; they just differ in there use to that of System B and C.Difference of Lathe A and B version is G98, G99. A-version lacks it
Not talking about revisions. G-code list. Its a parameter setting in Fanuc.
e.g. Fanuc -TB
The letter suffix on the control type is the control revision, not related to the g code system used on the control.
Also, when System A is used, U, V, or W can't be used as an axis name. Accordingly, G code system B or C is used for multi axis Turning Centres.
Hello mikiemus,
I would be very surprised if that is the case, as selection of Absolute/Incremental by G90/G91 respectively is one of the aspects that sets G Code Systems B and C apart from System A. I've not seen a case where Incremental or Absolute commands can be executed by both G90/G91 and XZ/UW respectively in a Fanuc control set to use either G Code System B or C.
Because Fanuc controls are supplied to a wide range of MTBs, according to my Fanuc Colleagues, System B and C are provided to give comparability with other controls. Also, when System A is used, U, V, or W can't be used as an axis name. Accordingly, G code system B or C is used for multi axis Turning Centres.
Regards,
Bill
Notice
