8strings8rounds
- May 11, 2017
Hi, I'm new here and this is my first post..
I am programming and running a DMG Gildemeister Sprint 20/5 Swiss machine equipped with Fanuc 32i model B
We run tool steel and make blanks with squares (4 flats at one end)
Mr. Bossman bought this machine because he was told "squares are free"- meaning we can square on the sub while turning on the main.
Here's the problem: NO Y AXIS on the sub. Live tooling, yes, but I'm limited to polar interpolation (G12.1) using X and C. I'm using a carbide, .375" end mill and what's happening is my speeds and feeds are amounting to a painfully long cut time.
I use a tiny indexable mill on the main and it can crank through parts like nothing, and the inserts are cheap and last long. The carbide end mill on the sub breaks down quick and costs 5x that of a set of 4sided indexable inserts..
Bossman is convinced there's a better way.
I don't know if there is?
Sorry for the long, rant-like post, but I'm lost.
Tooling suggestions, speeds/feeds, anything would be much appreciated.
Thank you
Thank you
