Ukraine Train
Cast Iron
- Feb 10, 2014
- Ohio
I'm making some .25" deep x .390 wide grooves in heat treated 4140 using a top notch 1/8" wide groover with the coating that the insert supplier recommends (Horizon). Finished diameter at the groove is 5.0". I started at 400sfm and .003IPR but was getting a lot of chatter on the finish passes so I slowed down the finish passes to 200sfm. This got rid of the chatter but the finish is still pretty rough and I need to be hitting 32Ra. Any suggestions? The insert lines up right on the tangent of the stock, or maybe .015" high. There is no chip breaker. I'd like to be using a wider insert but this is the widest one they have with a sharp corner radius.
Thanks!
Thanks!
