Hi,
My company owns a Haas VF-2 and did a ballbar test (QC2 -W ballbar system). I'm trying to interpret the results. Everything looks reasonable except the positional tolerance, which seems high.
Here are some results:
Radius= 5.905512"
Circularity 0.000346"
Positional Tolerance 0.003268"
Scaling Error X 0.098 thou/in
From some google searching, I found this from a brochure:
"In addition the ballbar software will automatically calculate a
positional tolerance for the tested machine. (The positional
tolerance value is an estimate of the planar, bi-directional
positioning accuracy of the machine, within the area enclosed
by the ballbar test, and under unloaded conditions.)"
I guess I have two questions:
1.) How exactly is this true position defined? What is the datum? How much worse will this get if I'm machining at a larger radius?
2.) Is a 0.003" positional tolerance typical for a VF-2? It seems like it's an order of magnitude off from the other errors (circularity for example).
Thanks for your help!
Radius= 5.905512"
